abs inop and asr off lights
Old 03-26-2010, 05:30 AM
vatechguy3's Avatar
Default abs inop and asr off lights
so i finally got around to installing my new arp studs so i could mount up my new 18x10.5s all the way around.
the fronts were no problem, just beat out the old and pull up the new.
the rears seemed to go ok. i removed the sensor, and used that hole to pass the old studs out and install the new ones. everything seemd to work great and i replaced the sensors after the studs went in.
got the wheels and tires mounted up and went for a test drive.
got "abs inop" and "asr off" lights on and stayed on during the entire test drive, including 3 engine stops and restarts.
the lights did not go out during the 20 min test drive.
trying flipping the asr switch, but that didn't work.
do i need to replace one or both sensors? how do i check to see if they are working properly??
one other thing, the brake light is OFF and works perfectly when the e-brake is pulled up.
any other advice?
thanks
tony
Old 07-02-2010, 06:23 PM
Josh40601's Avatar
hey man did you ever get this situation figured out? My vert has the same problem
Quick Reply: abs inop and asr off lights
