No brake lights on passenger side.
I have a strange issue where I have no brake lights on the passenger side of my Firehawk. The lights light up in the "low" level when I turn the headlights on, but when I press the brake, they don`t switch to the "high" level (sorry for the non-technical description). The driver`s side is working fine though. I took the two lamps from the drivers side, which is working fine, and put them in the passenger side and I get the same results so it is not the bulbs. There is no obvious cuts or breaks in the wires right behind the tailights. The only thing I can think of is a wire is broken somewhere along the path, but I wanted to make sure with you guys to see if it is something simpler before I trace all these wires. Any ideas?
Thanks!
Thanks!
Save the manuals!
If you trace the dark green wire back through the car, you should find your issue. (The brown wire is your good one and controls the filament that comes on with the headlights.)
Yep. The bulbs are dual filament. That gives you the low/high effect. You must have one of the wires out or cut somewhere.
Did you ever figure this out? I am having the same problem, but with my drivers side. For a couple of years, the problem has come and gone. Sometimes the ds brake lights would work, and sometimes they wouldn't. Now it has quit completely. I need to get this figured out.
