LS1 Coolant Temp Sender Warning Trigger
Old 03-26-2010, 10:44 PM
bluemach1's Avatar
Default LS1 Coolant Temp Sender Warning Trigger
Does anyone know the temperature that trips the coolant warning light on a LS1 engine? FWIW, it is from a 2000 Trans Am.
Doing a conversion into a 944 and need to know this for VDO sender.
Thanks,
Ted
Old 03-27-2010, 08:06 AM
Jimbo1367's Avatar
LS1Tech 10 Year
what does......... " FWIW" mean?
Old 03-27-2010, 08:18 AM
the_merv's Avatar
LS1Tech 10 Year
For what it's worth..
Dont know what temp trips it..I would thing it's around 240*.
Old 03-27-2010, 08:28 AM
Old Geezer's Avatar
I don't think it's the sensor that trips it. The trip point is a programmed item....
Old 03-27-2010, 10:43 AM
bluemach1's Avatar
Correct. The sender in the head leads to the ECU and the rest takes place there. The stock 944 sender is set up to have the analog needle gauge and a warning light that trips at around 115, if I recall correctly, and it is triggered right from the sender. That 115 is for the turbo four banger. I know that I am going to need something hotter than that but dont know what stock GM trigger point is. I wonder what is programmed in the GM ECU stock?
Old 03-28-2010, 08:38 AM
Old Geezer's Avatar
"I know that I am going to need something hotter'....the 115* referred to is cel..
115C = 239F
Old 03-28-2010, 10:48 AM
bluemach1's Avatar
Yes, 115 Centigrade. On another forum I read that the "hot" light on camaros indicates at 250 - 258 Farenheit. Dont know if this is for LT's or LS's or both....
Old 03-29-2010, 09:18 PM
poconojoe's Avatar
I don't think its programmed in the PCM, I think its a function of the cluster programming
Quick Reply: LS1 Coolant Temp Sender Warning Trigger
