1999 firebird, 5.3 lm7 engine swap question
Old 03-27-2010, 03:53 PM
hempseed426's Avatar
Default 1999 firebird, 5.3 lm7 engine swap question
im swapping out the 3.8 for a 5.3 from a 2000 surburban and i was wondering if anyone knows if the truck intake will work with the swap cause of the clearence issues with the cowl/firewall since the intake is taller
Old 03-27-2010, 08:43 PM
1quickirocz's Avatar
no the truck intake will not work. also im not sure but i dont think the truck acces will work either.
Old 03-28-2010, 05:27 AM
the_merv's Avatar
You will need F-body LS1 Accessories & Oil Pan, K-member & Mounts, Steering Rack & Linkage, LS1 PCM & Wiring, and a Car Intake.
Old 03-28-2010, 02:03 PM
ok, what about the v6 tranny can the bell housing be swapped out for one that fits
iim trying to keep the cost as low as possibe but at the same time di it right without rigging things
Old 03-28-2010, 03:48 PM
the_merv's Avatar
Auto or Standard?
Bellhousing on a V6 Auto doesn't come off..and you will want a T56 if you are a manual.
Old 03-28-2010, 04:01 PM
its the auto 4l60e there are bolts that look like the bell housing is removable
Old 03-29-2010, 09:32 AM
the_merv's Avatar
Post a pic up..
Old 03-29-2010, 03:18 PM
383lt1guy's Avatar
im doing a simiar swap except into my 94 trans am but since its an lt into an ls i need pretty much all the same things can u make this a build thread to help me out a little.
Old 03-29-2010, 03:21 PM
the_merv's Avatar
Here is a plethera of info for ya bud..
https://ls1tech.com/forums/conversio...to-95-z28.html
Old 03-29-2010, 06:03 PM
at the moment i dont have a camera but ill try to get some pics up. what is the reason i cant use the truck intake, im pretty new to gm's
Old 03-30-2010, 12:28 AM
the_merv's Avatar
The Truck Intake is really tall..I don't think it would fit under the stock Hood of a car.
Old 03-30-2010, 02:25 AM
slow00gt's Avatar
Truck intake is tall. gonna say it will not fit under a stock hood. Also get the LS1 accessories. Having the alternator up top looks terrible in a car especially with a car intake
Quick Reply: 1999 firebird, 5.3 lm7 engine swap question
