LS1 Replacing Headgaskets w/o pulling the motor?
Old 03-28-2010, 02:22 PM
Torquewrench87's Avatar
Default LS1 Replacing Headgaskets w/o pulling the motor?
Hey yall i was wondering if its possible to change the headgaskets without pulling the motor on a 01 Trans-am i have never done this before on a ls1..but it needs to be done its not blown real bad no coolant in the oil but it is burning it and i also seen a small wet spot under the passenger front side of the motor... so are there any write-ups or videos on how to change em w/o pulling the motor out?
Old 03-28-2010, 02:24 PM
bigj2717's Avatar
Yes it is possible. Its really not that hard to take the heads of while the motor is in the car
Old 03-28-2010, 02:35 PM
twelver12's Avatar
possible yes, pain in the back yes, be sure thats what you need though before you do it
and use gm head gaskets
Old 03-28-2010, 02:44 PM
Alright good thats what i wonted to hear.. i was thinking a good set of fel-pro's why gm?
Thanks for the quick replies yall
Old 03-28-2010, 02:58 PM
matt1289's Avatar
http://www.ls1howto.com/index.php?article=2 set by step how to
Old 03-28-2010, 03:32 PM
DVS99TRANS's Avatar
^^^ That is a great source, just be sure to get out as much coolant as possible. You don't want it to end up in your cylinders when you pull the heads. Plus if you have had thoughts of putting a cam in if you haven't already, this would be a good time.
Old 03-28-2010, 03:58 PM
Thanks yall and that website is gunna help alot thanks matt.
Quick Reply: LS1 Replacing Headgaskets w/o pulling the motor?
