93 Camaro Z28 Auto to Manual Swap
Old 03-28-2010, 11:01 PM
93 LT1 4 Speed's Avatar
Default 93 Camaro Z28 Auto to Manual Swap
I have a 93 Z28 Camaro automatic that I want to swap to a 6 speed. What all will I need? So far I know trans, bellhousing, clutch, clutch mater cylinder, slave cylinder, peddle assembly...will it require a different cross member, driveshaft, any cables? I may be forgetting things so add them and any extra knowledge about the swap is much appreciated. Thanks. Also if anyone knows where I can get my hand on a complete set up I would love to hear...preferable in the midwest.
Old 03-28-2010, 11:09 PM
bigj2717's Avatar
Well since you're new to the forum welcome. The search and stickies are going to be your friend here because what you are looking to do if very common. Here is the sticky which sound answer most of your questions https://ls1tech.com/forums/manual-tr...requested.html
Quick Reply: 93 Camaro Z28 Auto to Manual Swap
