LS6 intake issue
LS6 intake issue
Hey guys after doing my LS6 swap my idle has been real funky. It sticks sometimes at 1400 when cruising then when I come to a stop it will slowly come down to 1000. I sprayed the entire intake down for leaks and nothing. I am also getting a really strong antifreeze smell to top it off. I hooked the car up to a scanner to do an IAC test while I can adjust it to 1200 and the idle moves. If I try to drop it down to say 500 nothing happens. I am stuck right now any advice would be appreciated thanks....
Ok found the issue after doing a smoke test on it. It is leaking at the back connector thats bolts into the intake. My question is does this come out and if so how? 2nd is there a gasket for it? If it doesnt come out what is best to lock it into place? Thanks
