SS Brake Line Install Help.
Old 03-30-2010, 08:08 AM
ICRAZY6's Avatar
Default SS Brake Line Install Help.
Just looking for some info on the install. I purchased a set of RPMSpeed Stainless Steel Teflon Brake Lines Front and Rear.. WITH Traction Control from WS6store and there weren't any directions. Is there anything to be carefull with while disassembing? Where does the line for the Traction Control go? Searched for a write up but found nothing.
Thanks for the help.
Old 03-30-2010, 10:24 AM
Big_Bird_WS6's Avatar
the traction control line goes from body to the rear. by the pumpkin.
and be careful with it all. just do one at a time. then bleed the whole system
Old 03-30-2010, 10:55 AM
ICRAZY6's Avatar
Yeah, going to flush it all.
Old 03-30-2010, 12:41 PM
mitchntx's Avatar
A traction control kit should have 6 lines total. One for each corner of the car and two lines at the diff.
Buy some cheap brake fluid and make sure you keep the MC full. Keep topping it off with the cheap stuff. Then flush it out when you are complete with the line R&R.
Old 03-30-2010, 01:33 PM
i agree. i did not know to do this when i did mine. and my abs unit went dry. bad deal. the dealer had to flush it to attivate my abs unit
