Western Members CA, AZ, NV, UT, CO, NM, HI
Engine and Tranny swap!!!!
Old 04-01-2010, 11:40 AM
chevy619's Avatar
Default Engine and Tranny swap!!!!
I have a 01 SS, and I'm about to get a 04 GTO engine and transmission. It only has 35xxxmiles on it. I dont know a lot about swapping engines and all that. My question is if i do a complete swap would everything fit up ok. I been asking around a few shops here in San Diego, but i would like some of your guy's opinions, and advise.
Old 04-01-2010, 12:50 PM
Arc00TA's Avatar
Things you will need to do:
- Swap f-body oil pan
- The balancer is the same, the accessories may need to be swapped
- Engine harness needs to be swapped to your f-body one
- Possibly change the motor mounts, I don't know if they are different
It should be pretty much a drop in, what tranny did you get? The GTO MN12 has slightly different gear ratio than the T56, so your computer might have to be retuned to compensate for that.
Old 04-01-2010, 01:18 PM
lowerthanyou00's Avatar
Don't forget the shifter it need a f bod setup
Old 04-01-2010, 01:19 PM
ss.slp.ls1's Avatar
Pretty much what he said, swap on the oil pan, windage tray, pick up tube, acc's, and that's it. Now is the best time to throw in a cam and some long tubes. let me know when you plan to get the swap done. I can do it for you on location.
Old 04-02-2010, 12:03 AM
BigDaddyBry's Avatar
What happened to your motor?
Old 04-02-2010, 11:30 AM
m6ttop's Avatar
X2 on the shifter... I think the GTO shifter is angled to the right
Old 04-02-2010, 11:55 AM
ss.slp.ls1's Avatar
Does that include the shifter cup?
Quick Reply: Engine and Tranny swap!!!!
