Electrical help please, fog lamp problem
hi all,
my fog lamps arent working. i checked the bulbs and relay and they are good. when i turn on the parking lamps and then turn on the fog lamp switch, my switch doesnt illuminate. Same thing happens on low beam. If i turn on my high beams my fog lamp switch then illuminates. My fog lamps never come on. This is on a 2000 camaro. Any help would be greatly appreciated.
If the indicator comes on when you have the brights on, but at no other time and the lights never come on, then it sounds like a short\ground in the harness. But you should check the bulb sockets to make sure they didn't get gunked up in the rain. That used to happen to my turn signals, but not the fog lamps.
