Key Fob not working... Stuck in San Diego!
I'm out here visiting SD, 3 hours from home, and I can't unlock and disable the alarm. The car isn't responding to the key fob even with a new battery. Is there any way of getting around this? The alarm will go off if I key it open, right? Any help would be much appreciated!
From what I remember, if the factory alarm is armed and you don't disable it, but you unlock the door with the key only without deactivating the alarm, the alarm will go off audibly until you get in and start the car, and then it will disable.
