master to slave braided line question
Old 04-04-2010, 09:25 PM
QUICKQTR's Avatar
Default master to slave braided line question
Does anyone know if you can get a custom length line that goes from the master to the slave? The factory length setup is too short for my application...
Old 04-05-2010, 12:24 PM
sbackof's Avatar
yes you can I just ordered one However, 2 questions, 1 who made your MC and or 2 do you know the type of fitting on your MC, AN3 AN4??? There is only 1 company that makes them as it is discontinued from GM. Speedway motors makes 3 lengths none of which are the stock lenght but are close since stock is too short they have 2 that would and or should work for you I think the longest is 40 inchs give or take. Now I could be wrong but I believe the end is a AN4 and GM uses a AN3 or other way around. I have a Mcleod Gen 1 MC, and it uses the opposite of what they use, so your going to need an adapter possibly AN3 to AN4 to connect the 2. They actually called Mcleod for me and verified the fittings so there would be no issues. Currently they are the only one on the market that sells them, at least that I could find. 18009790122
Quick Reply: master to slave braided line question
