Problems with full exhaust install
Old 04-06-2010, 10:54 PM
noflyby99's Avatar
Default Problems with full exhaust install
Just installed my new exhaust and put the PCM back in after getting it tuned by Ion. Turned the key it started up idled for about 30 sec got some good pedal out of it and then it died. When I try and help keep the revs up the car just dies. EGR and AIR are removed and tuned out, plug wires are all connected (checked and rechecked) EGR port in top of intake manifold is sealed. I'm kind of stumped thought it may be an exhaust leak but I can't hear a leak. Any info you guys can give me will help thanks.
Old 04-06-2010, 11:09 PM
conor.davis's Avatar
https://ls1tech.com/forums/generatio...wont-idle.html
might check that?
Old 04-07-2010, 05:41 AM
ChrisUlrich's Avatar
Originally Posted by conor.davis
That'd be my cousin! hahahah
Guess he didn't know I posted already!
Old 04-07-2010, 03:06 PM
blackfbird98's Avatar
take some shop solve or brake cleaner and spray by your vaccum lines you can see if there are any leaks when it bubbles
