Tick Master, What brake fluid ?
Old 04-08-2010, 02:40 PM
Bad Notch's Avatar
Default Tick Master, What brake fluid ?
Dot 3, Dot 4, or Dot 5 ?
I been trying to call them but the line is busy and I want to get this thing bench bled asap.
Thanks
Old 04-08-2010, 03:19 PM
99ssleeper's Avatar
use whatever the owners manual calls for. i believe its dot 3. i used dot 4 in my stock system. you should have no problem either way.
Old 04-08-2010, 05:23 PM
Demonicbird00's Avatar
installed the tick today along w/ a new clutch reservoir (wilwood) and i put gm brake fluid in
-brandon
madmike9396's Avatar
did u have the sticky pedal ?
Old 04-08-2010, 05:47 PM
Redneck Z's Avatar
Dot 3
Old 04-08-2010, 06:26 PM
NSSANE02's Avatar
3 or 4, both will work.
Old 04-08-2010, 08:12 PM
Black02SLPSS's Avatar
Either of those will work. Or if you can find some DOT 5.1 that will work too. Just dont put DOT 5 in.
Old 04-08-2010, 08:59 PM
NSSANE02's Avatar
Don't you have to flush it out real good if you switch to 5.1 so they don't mix? I thought I remember reading something about that.
Old 04-08-2010, 09:05 PM
Bad Notch's Avatar
Why not dot 5 ? I didnt have any pedal issues.. im just upgrading the whole system.
Old 04-08-2010, 09:11 PM
NSSANE02's Avatar
It has something in it that's bad for the hyd. system, I forgot what it was though. That, and there's no reason for it... go with DOT 4 and be done.
Old 04-08-2010, 09:12 PM
FirstLSx's Avatar
DOT 5 is not compatible with DOT 3/4
Old 04-10-2010, 01:40 AM
YOOFORMULA's Avatar
I was told that anything other than dot 3 would deteriorate the seals in the master. I had to rebuild mine twice after the rubber seals inside tore apart due to the fluid.
Old 04-10-2010, 03:15 PM
Viper's Avatar
"I had to rebuild mine twice after the rubber seals inside tore apart due to the fluid."
Tick, stock or McLeod?
Old 04-10-2010, 07:11 PM
NSSANE02's Avatar
DOT 4 will be fine. I've been running it for over a year.
Old 04-11-2010, 11:46 PM
YOOFORMULA's Avatar
mcleod master. the rubber seals were gummy and fell apart inside the cylinder but in hind sight, it might have been the synthetic brake fluid I used at one point.
Old 04-12-2010, 02:51 AM
Its not a problem as them not being able to be mixed with each other, but you would want to flush the system very good so that your not cross contaminating the new fluid with the old as the 5.1 will have a higher resistance to boiling vs the 3 and 4.
And DOT 5 is a silicon based brake fluid where as DOT 3,4 and 5.1 is a Polyglycol ether based fluid. So thats why if you put a silicon based fluid in a system designed for the polyglycol ether based fluids you will have a premature failure of the seals and what not.
Quick Reply: Tick Master, What brake fluid ?
