25.5 Mustang Coupe project.
Wolf mini tubs going in. One down and one to go. I should have both in by this weekend. Then I can start mocking up the LCA mounts. I got a little aggressive with the overall housing length. I had Moser cut off 3.5" per side and leave off the LCA brackets so I could custom fit those myself. I'm hoping I can get a 12" rim and 325" behind the wheel well lip... We'll see.
OK... Both tubs are spot welded in, so that's basically done. And I hung the housing from the upper mounts to see where my LCA brackets will need to go and it looks like it won't be a problem. So then I lowered the car and stuck a 325 DR in the wheel well to see how all that would clear... It fits great, and below is the look I'm shooting for.. I'll order a Strange brake kit next week and mount them up for real to see "for sure" what back spacing I'm going to need...
Thanks, JR. I just received the full length Wolf through floor sub-frame connectors, and I'll be putting those in next week. After those are in, I can start putting in the cage. I also got all the front suspension stuff coming from RaceCraft... It should be here next week so I can start mocking that up too. I'll post a few more pics once that starts going together.
7 Second Club
The cage is still under construction but I got the front and rear suspension is mocked up. Now I'm working on the rear anti-roll bar set-up.
Attachment 234131 Attachment 234132
Thanks, guys. And yes, the AFCO shocks are better, but they were not in the budget for this project. It won't be a big HP car, relatively speaking... 700-ish, NA... And 900-ish with nitrous.
And I got the anti-roll bar set-up mocked up (It's just tacked welded in so don't beat me up about the welds) Other than that, I'm very pleased with it and the way it all came out. It's super strong and all the moving parts are easy to get to and removable... Note the splines at the end of the shaft. You can clock the arms 360 degrees for any arm angle and down bar length.
That is a good deal. No matter how fast it goes, you are covered..
I take it you have been at this whole fabbing thing for a while now. The work is really nice.
What kind of power plant are you thinking of running at this point?
