Memphis or kicker for 50 x 4
I'm torn. I can get a Memphis 50 x 4 stereo amp for $200 new. My buddy had one in his TA with all MC SYNC C6's and it sounded AMAZING!! But I've had my eye on the Kicker 50.4 for years now.
Specs and ****.
KICKER
CLASS D SUB CHANNEL 18dB CENTERED AT 40HZ 12dB/OCTAVE HIGH, LOW, OR ALL-PASS CROSSOVER IN HYBRID SUB CHANNEL DIFFERENTIAL INPUT FOR NOISE ELIMINATION; FULL RANGE REMOTE GAIN CONTORL
MEMPHIS
* Full MOSFET Design
* User Selectable 12dB or 18dB Per Octave Crossover Slope
* RCA Bypass Output
* Platinum Finish Wire Connections
* Accepts 4 Gauge Power and Ground Wire
* 4-Channel MClass Series Amplifier
* Compact Aluminum Chassis with Custon Black Pearl Finish
* Gold Plated RCA Connectors
* RCA Outputs: 1 Pair
* 4-Way Protection Circuitry
* Optional Wired Remote Gain Control
* Adjustable Input Sensitivity: 250mV - 5V
* Number of Channels 4
* RMS Power (4 ohms) 50 watts x 4 chan.
* RMS Power (2 ohms) 75 watts x 4 chan.
* RMS Power (1 ohm) Not Stable
* Bridged RMS Power 150 watts x 2 chan.
* Peak Power Output 600 watts approx.
* Min. Impedance Unbridged 2 ohms
* Min. Impedance Bridged 4 ohms
* THD @ Rated RMS Power 0.03 %
* Amp Preamp Outputs Yes - 1 Pair
* Built-in Crossover HP (400 Hz - 6 kHz), LP (40 Hz - 600 Hz)
* Signal-to-Noise Ratio 92 dB
* Fan Cooled No
* Fuse Rating 40A x 1
* Dimensions: 14.1875" L x 7.6" W x 2.4" H
Memphis 16MCA2004 Memphis 16 MCA2004 50 x 4 Class AB Full Range Amplifier 16MCA 2004 16 MCA2004
He had this one:
# PR amplifiers are loaded with goodies you don't find in other amps in this range. Like fully variable crossovers. Platinum finish terminals. Cooling fans. And LOTTS of clean power! 100 Watts Full Power RMS @ 2 Ohms
# 70 Watts Rated Power RMS @ 2 Ohms
# 50 Watts Rated Power RMS @ 4 Ohms
# Extra Low: 0.05% THD
# Frequency Response +/- 0.5dB 20Hz - 20kHz
# Dimensions (in) 9.5 x 2 x 14.25
# Built in Cooling Fan
# Fuse rating: 25A X 2
Memphis 16PR100.4 Memphis 16 PR100.4 50 x 4 Power Reference Amplifier
Specs and ****.
KICKER
MEMPHIS
* RCA Bypass Output
* Fan Cooled No
He had this one:
