Does the ABS block have to remain upright to function?
Old 04-20-2010, 05:40 AM
00CaliforniaZ28's Avatar
Default Does the ABS block have to remain upright to function?
Ive been throwing around ideas in my head to relocate the ABS block, but was wondering if itll function if I tip it on its side to hide it, or if it has to remain vertical and level to function properly? I guess theres always the ABS delete kit, but Im seeing if I can make this work first... Thanks
Old 04-20-2010, 12:18 PM
Black02SLPSS's Avatar
I would think you can mount it in what ever position you want as long as you bleed it out in the stock position first, I would think it would be a PITA to bleed it out upside down. But then again i hear its a PITA to bleed as it is.
Quick Reply: Does the ABS block have to remain upright to function?
