Newbie help
Old 04-20-2010, 07:27 PM
61 Impala's Avatar
Default Newbie help
Howdy, I put an LS1 in my 61 Impala and I am now getting around to hooking all the harness wires up. I have an after market harness. The first picture shows a little female connector, of which I have no idea what connects to it??? I have no extra wires (excpet for my o2 wires) I've attached a couple of pics. The first pic has a red arrow pointing to the unit.
What am I missing? Thanks in advance!!!!
Attached Thumbnails Newbie help-intake-pics-001-arrow.jpg   Newbie help-intake-pics-002.jpg   Newbie help-intake-pics-003.jpg
Old 04-20-2010, 07:45 PM
DaynNight's Avatar
is the 1st picture of back of the intake? looks like a map sensor
Old 04-20-2010, 07:48 PM
61 Impala's Avatar
Yes, the first pic is the back of the intake. (sorry) If it is a map sensor (?) whatever that is, do I need it?
Old 04-20-2010, 08:06 PM
DaynNight's Avatar
A manifold absolute pressure sensor (MAP) is one of the sensors used in an internal combustion engine's electronic control system and yes you do need it
Old 04-20-2010, 08:09 PM
DaynNight's Avatar
becarful not to break it, to remove it you need a map sensor socket. there should be a plug in on the harness
Old 04-20-2010, 08:19 PM
61 Impala's Avatar
oh oh, me thinks me in trouble. I have no extra wire to connect to it. I ran the engine in the frame before I put the body on it, and it ran fine. The computer was tuned for my application, does that make a difference?
Old 04-25-2010, 07:21 PM
61 Impala's Avatar
Default Anyone else want to chime in?
I'm really not sure, so anyone else got an opinion?
Old 04-25-2010, 07:49 PM
bayer-z28's Avatar
The first one is the oil pressure sending unit. The map is a smaller one with an angle 3 pin connector plugs into a gromet into the back of the intake.
This is a MAP sensor...
THIS is the oil pressure unit, yes it is fragile.
Old 04-26-2010, 09:12 PM
61 Impala's Avatar
Excellent, thanks. The MAP sensor is connected. According to my wiring guy, I don't use the stock oil pressure sensor. That's why the engine ran with no problems without the oil sensor being connected. I have to drill and tap a hole somewhere near the oil filter to use after market gauges.
Thanks for the help!!!!
Old 04-26-2010, 09:30 PM
bayer-z28's Avatar
No problem. Are you going to leave the oil pressure unit in there for now? You can prolly find a pipe thread plug at a hardware store if you take it out.
