Notices
wtb parts!!!!!
Old 04-24-2010, 12:50 AM
dgcustomz's Avatar
Default wtb parts!!!!!
Part I need:
*navy blue metallic rear bumper
*oem battery cables... I need the complete setup that includes the negative cable that goes near the crankshaft position sendor and the small wire that goes on the passenger side wheel well, and positive cables and the power cable that goes to the alternator and fuse box and starter.
*A/c compressor... must be working and you must guarantee that it works!
* computer mounting bracket
* Pigtails for ls1 fans---found
*brake booster hose that goes to the rear of the intake also needs to have the plug that goes into the brake booster---found
*Braided ground strap that goes from the lower driver side block to the chassis under the fuse box---found
*pcv hose that goes from the passenger valve cover to the tb---found
Pm me or call me.. 817-353-9562. Thanks alot guys!
Old 04-24-2010, 01:23 PM
slolt1's Avatar
i have the a/c compressor,the booster hose and fitting,i should have the ground strap also pm me a offer
Old 04-24-2010, 04:49 PM
dgcustomz's Avatar
I have updated the thread with what I found so far.. slot1- please send me a price shipped to 76105 on the a/c compressor. I will need you to guarantee me that it works. I don't want a " I think it works". Thanks
Old 04-25-2010, 07:17 PM
DemonInside's Avatar
i have a set of the oem battery cables pm me if you still need them
