Moser 9" + stock d/s = what yoke?
Old 04-25-2010, 07:21 PM
tnmotown's Avatar
Default Moser 9" + stock d/s = what yoke?
Just like title says. I got a Moser 9" and will be using my stock driveshaft. Now I understand I need the 1350 u-joint from NAPA for the driveshaft, but then what pinion yoke will I need on my 3rd member? I'm just kinda confused here, and did a lot of researching. Thanks everyone for any input.
P.S. any good sites for pic-by-pic installation process?
Old 04-26-2010, 03:42 PM
Moderator
thechef's Avatar
what ever yolk is on your 9 inch is the yolk you need on your drive shaft
so if you ordered your 9 in with a 1350 yolk go to NAPA and get the 1350 yolk for the drive shaft
Old 04-26-2010, 06:49 PM
tnmotown's Avatar
Oh ok, makes sense. I just heard that there are like 3 or so different pinion yokes. Some are shorter/longer then others....?
Old 04-26-2010, 07:36 PM
welman transam's Avatar
the u joint you need is a precision #447 that is a conversion u joint because the stock driveshaft is not a 1350 just the yoke is i just did this 2 days ago.
Old 04-26-2010, 10:21 PM
tnmotown's Avatar
Yeah but I heard that the pinion yokes could be 1310/1330/1350 yokes? So I just assumed if those were different then the u-joint to the d/s will be different.
