All my electronics are cutting out! whats wrong?
i haven't had this problem in a while, and when i do, it just happens a few times and goes back to normal. for some reason, at random times while i'm driving, all of the electronics will cut out: radio, windows, etc. For no reason, they just cut out. and then they'll come back on, sometimes flicker on and off a little. but then it usually goes back to normal after a minute or so and then stay on.
so whats the deal. why is my car doing this?? its the camaro by the way.
a friend suggested that a ground may be loose or something? but he wasn't really sure about it, and i have no clue either. so i'm hoping someone can point me in the right direction.
It's your Body-control-module. You can either replace it, or try to repair it like the rest of us have....Lemme try and find the link...
https://ls1tech.com/forums/general-l...blems-fix.html
GM quality control GO!!!!!
x2 on BCM, but i like this link better: http://www.fbodyonline.com/how-to-fi...dio-and-locks/
shows pics of everything. And its an easy fix once you figure out what you're doing. Took me about an hour or so.
