Need Help!
Need Help!
When i used my nitrous i only gained lost about 5 tenths. I used the dry NOS set up and i am runnin the 100 shot jets. I think somethin is wrong becuase i should be runin faster. I have my nitrous comin strait in front of the K&N FIPK.That could be the problem or i need a bottle warmer(usually around 900 psi). But definatley I think there is a problem so can anyone help me out and tell me the problem thanks!
Yes you need a bottle warmer. Also need to switch to TR6 plugs. I had A custom tune to add fuel, this helped out alot on my car. And last but not least your MPH in the quarter is good but your 60' is the bigest single thing hurting you. Im guessing you need tires and practice. good luck
