stock oil temperature sensor thread size
Hey guys, I'm looking for a solution to my gauge sensor dilemma. I planned on using the stock oil pressure location for my oil pressure sensor and tapping the oil cooler block off plate for my oil temperature sensor. I'm running Auto Meter gauges.
The problem is I screwed up my block off plate and my oil pressure sensor doesn't fit where the stock sensor was located. So my solution is to use a product like this:
http://www.totalperformanceengineeri...oducts_id=1016
This would allow me to run my pressure and temp sensor in the same location. However, I can find what the stock thread size is for the oil temp, which this plate accepts. I need this solely to buy the correct adapter.
Searching has not yielded any results and contacting the company who makes the plate has been less than helpful.
Any help would be greatly appreciated!
Check this out. Its has three holes; cheaper and better looking. multiple vews http://cgi.ebay.com/ebaymotors/Chevr...item335c617ad3
