Width of stock 4th Gen rearend
Old 04-28-2010, 11:21 AM
1961ba427's Avatar
Default Width of stock 4th Gen rearend
Can you tell me the flange to flange width of the stock 7.5" 4th Gen 10 bolt?
Any other known flange to flange width of other vehicles is welcome also.
Thank you!!
Sorry for not searching, but would be late for work.
Old 04-28-2010, 01:44 PM
96lt1m6's Avatar
4th gen rear length from outer axle flange to outer axle flange is 64.72"
Old 04-28-2010, 07:29 PM
1961ba427's Avatar
Thanks man!! Been looking at the 8.8 builds, and was thinking of going that way, but wondering about maybe going with a 8.5" ten bolt or a 12 bolt (factory housing converted, not factory). I already have some posi units, housings, and gears for both of those, plus the 4th gen brakes will bolt right up to the housing ends. I just have to find one that is about the same width.
Old 04-28-2010, 08:50 PM
96lt1m6's Avatar
The 8.5 is a great rear end! We ran them EXTREMELY hard in the GN/T-types years ago with only MOSER c-clip elim axles never a failure running 9.30s up to stock...
I truley prefer keeping it chevy but at this time the 8.8 already had gear and locker for 150.00 it was an upper management decision aka "my wallet" lol
cannot discount the 12-bolt either its an awesome unit
Old 04-28-2010, 09:19 PM
1961ba427's Avatar
I have been wondering if there is an 8.5" that would has a relucter wheel on the center section (94-96 B-body maybe?) that will work with the 3 channel ABS sensor? I asked a local Fbody guy here, and he replied "just buy aftermarket 12 bolt set up for it." He just doesn't get the "upper management decision" thing.
Almost 65" is pretty wide as far as rears go, so I'd think it shouldn't be hard to find one close to that. I've also got a pair of 2" think wheel spacers I could run if I have to.
Quick Reply: Width of stock 4th Gen rearend
