Sponsored by: DashLynx
Rake stance wanted. What do I do?
Old 10-23-2002, 02:42 PM
PlowTown Missile's Avatar
Default Rake stance wanted. What do I do?
I am running DragLites all around with skinnies in the front. I want my car to sit around 2 inches lower in the front than the rear and still launch awesome. I have no swaybar but the rest of the suspension is stock. I was thinking that the Lakewood Drag Launch springs with airbag are the answer to my problem. I don't want to cut my coils but I would put lowering springs in the front if it would be ok to drive it that way. Any advice anyone? Any pics you've seen?
Old 10-23-2002, 03:43 PM
RTCamaroSS's Avatar
Default Re: Rake stance wanted. What do I do?
I dont see a problem with putting 1 inch drop coils in the front, and drag springs in the rear. That should give you the stance you're after, while still making it fully drivable.
Old 10-23-2002, 03:48 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Front QA1/ Hal shocks will lower the front of the car, especially if you use their springs.
