Ls1 dies after warming up.
My 2001 trans am will die, usually only when stopped after injas warmed upnfor 10-15 minutes. Afterwards I cannot crank it until it has cooled down. Are there any common problems with these cars that would explain this? He car has 75k miles on it. It wasn't my daily driver until my pos STi blew up on me... So I'm pretty desparate to fix it!
It will crank but wont turn over once it's warmed up. If you give a few tries it sometimes will again for a short while. I don't know about codes, there is no check engine light at any point.
is the engine stalling out or are you turning it off? if you are turning it off i would go with a starter shield or some heat wrap to keep the starter cooler.
