Infinity Kappa Perfect 6.1 Installation Q's
Hi, I have a set of Kappa perfect6.1's and was wondering where does everyone mount the crossover? It's pretty big.
Any how to's on this system? What about installing the tweeters?
Thanks.
Thanks.
I decided to use the factory high pass filter and not install the infinity crossovers. If I feel the need I can always come back to it. Got the tweeters installed also.
Next question is my 6.5's don't match the screw holes of the factory housing. The Kappa's come with an adapter plate but no where near close to lining up with the factory housing. What have you all done to get 6.5's to screw into the housing? Did you make your own adapter plate? If so, what did you do?
Thanks.
Thanks.
