question about vacuum assisted brakes
Old 05-04-2010, 08:40 AM
1_fast_gto's Avatar
Default question about vacuum assisted brakes
for those of you running a large cam, what are yall doing about the vacuum for the brakes? i recently picked up a cam specs are .232 .240 .600 .605 lift on a 112. do you have any problem with vacuum for the power brakes? if so what are you doing to make up for the lack of vacuum?
thanks
josh
Old 05-04-2010, 10:25 AM
QuickSilver's Avatar
I ran the MS4 and had no issues at all.
It was a 238-242 .652/.611 111
Just make sure your check valve if working and you will be fine.
Old 05-04-2010, 10:49 AM
1_fast_gto's Avatar
thanks
josh
