Monsoon Amp
Monsoon Amp
What are the rules for replacing one of these? Can I use a T/A amp in my Camaro for replacement, or does it have to be another Camaro amp? I believe year doesn't matter, as just the advertised rating changed.
Ungrounded Moderator
This is covered (sort of) in the Monsoon FAQ sticky but perhaps a little clarification is in order. You must use a Monsoon amp from the same model car (Camaro or Firebird) because they are different internally. The are both eight-channel amps but they use the channels differently (e.g. dual voice coil subs in Firebird versus single voice coil in Camaro), the rated impedance for each channel is different, and the signal is filtered differently.
Any Monsoon amp from 97 through 02 will plug in and work but the early models (all of 97 and part of 98) were physically smaller and produced less power so you might want to stick to something from a 99 and newer.
