Fuel problems ( Car will not start )
Did a cam, intake, injector, and all the other possible bolt-ons swap. Went to start the car to move it out of the garage and no luck. The car would not start. I removed the fuel line from the fuel rail to see if I had any fuel and no GAS. Looking for some help to find the problem. So if anyone is in the Enterprise Alabama area please stop by and give me a hand. All the beer and wings are on me. Here a contact for me 910-366-7405
Jay
Jay
So you're not getting any fuel to the rails? I'd check the pump relay and any connections you took apart while doing the install. I'm guessing you don't hear the pump prime when you turn the key forward?
Sounds like the fuel pump is bad, turn it on to the run position and tap the tank with a rubber mallet a couple of times, then try to crank it. there's not a hell of a whole lot else it can be, but getting to the fuel pump on a f-body is a nightmare! ask me how i know.
