This has bothered me since my 408 install.
Old 05-06-2010, 07:18 PM
ssdungeon's Avatar
Default This has bothered me since my 408 install.
I dont know if its hurting anything at all but what the heck is this? Its just attached to the return fuel line on my vette. Its not plugged or anything.
The part number is Delphi 997277. Should I just plug this return line? This is on my vette in the sig.
Attached Thumbnails This has bothered me since my 408 install.-160834.jpg   This has bothered me since my 408 install.-164095.jpg   This has bothered me since my 408 install.-photo_042810_001.jpg
Old 05-06-2010, 08:59 PM
Wesmanw02's Avatar
I believe that is part of the EVAP system.
Old 05-06-2010, 09:09 PM
SweetS10V8's Avatar
Its an evap purge solenoid. It has its own seperate hard line running from the tank to the engine compartment. As as fumes build in your gas tank, your tank used a MAP sensor in the tank to tell the PCM when to release the pressure.
The purge solenoid opens to release the gas fumes into your intake manifold to be burned. Its supposed to simply be run into the intake, typically a port next to the throttle body.
Old 05-06-2010, 10:24 PM
ssdungeon's Avatar
Default question?
So I would be fine to just leave it as it is.... its not going into my intake....
Old 05-06-2010, 10:41 PM
DAS1998's Avatar
Default purge
better then in the fuel line...
Old 05-06-2010, 11:11 PM
ssdungeon's Avatar
Default fuel line
So should I just block off the return line?
Old 05-08-2010, 06:59 AM
SweetS10V8's Avatar
You should put it to your intake. Its not harmfull in any way.
Old 05-08-2010, 08:33 PM
DAS1998's Avatar
if is not hooked up to the plastic evap line that goes to the tank, get rid of it. post up more pics of what you have going on.
Old 05-08-2010, 09:28 PM
ssdungeon's Avatar
Default Ok so just block off the return line.
If so ill just block it and unhook it.
Attached Thumbnails This has bothered me since my 408 install.-photo_042810_002.jpg   This has bothered me since my 408 install.-photo_042810_003.jpg   This has bothered me since my 408 install.-photo_042810_004.jpg   This has bothered me since my 408 install.-photo_042810_011.jpg   This has bothered me since my 408 install.-photo_042810_012.jpg
