walbro 255 pump
Old 05-14-2010, 10:22 AM
6801's Avatar
Default walbro 255 pump
i have a walbro 255 already i checked my fuel pressure with stock pump the car running and its at 40 psi should i change the pump before i get a dyno tune or leave it alone?
Old 05-14-2010, 05:55 PM
stryker1320's Avatar
If it were me, I would. If for no other reason than the fact that you have it. 40 psi at idle isn't bad.
Old 05-15-2010, 01:08 PM
koolaid_kid's Avatar
What are your mods? Do you need the increased volume? Your current pressure is within design parameters, given that you do not apparently have an adjustable FPR.
