Disengagement issues with Spec Twin disc
Old 05-14-2010, 06:58 PM
03 BUSA's Avatar
Default Disengagement issues with Spec Twin disc
I pulled the trans the other nigh to have it gone thru. I have always had a disengagment issue with this spec twin disc. It wants to bump the car forward when putting in gear. I have bleed this thing over and over again with a Tick MC. No changes. I have lenghthened the throw of the pedal with no changes other than a really high pedal. Now that the trans is out what are some things I can look at? All hyd. parts were/are new. Clutch does have a shim installed. It is not real bad just annoying at times. Also, for me to be able to go into reverse I have to put it into 1st before it will even think of going into reverse. If I let it bump forward in 1st then try reverse it goes right in like normal. NO grinding in any gear under any condition??? Just looking for some ideas. Thanks guys.
Old 05-17-2010, 12:18 PM
Kurtomac's Avatar
you may have bent the disks during install which would cause this issue...hows your high rpm shifting?
Old 05-17-2010, 12:19 PM
Kurtomac's Avatar
since its apart have the disks checked for straightness...hows the clutch look? pics?
Old 05-17-2010, 03:21 PM
03 BUSA's Avatar
Not an issue other than from a stop trying to put into gear.
03 BUSA's Avatar
Friend of mine is also having this issue once he put a few hundred miles on the clutch??
