Need Mezeire water pump info bad.
Old 05-20-2010, 06:57 PM
skidmarkSS's Avatar
Default Need Mezeire water pump info bad.
Where are you guys getting your 6 long bolts that go through the Mezeire electric WP and spacers if you have the front mount distributor?I check Wegner where i got the spacers and they don't know.
Old 05-20-2010, 07:10 PM
NoClassic's Avatar
They are m8x1.25x82.6.
Add the width of the spacers and order away.
Old 05-20-2010, 08:17 PM
rascalking's Avatar
If they're 3/4" spacers, the bolts need to be 100mm long. Granger has them in stainless allen head.
Old 05-20-2010, 08:23 PM
Steve VanS's Avatar
www.fastenal.com or www.mcmaster.com they got what you need
Old 05-21-2010, 10:24 AM
skidmarkSS's Avatar
The spacers are huge,probably 2in. at least,i will check these people out.
Old 05-21-2010, 01:10 PM
rascalking's Avatar
Looks like you will need 127mm long. 130 should work.
Old 05-21-2010, 04:05 PM
SOM68SS's Avatar
I got mine from my local fastenall dealer. I used allen headed bolts in all except one where I had to run a piece of all thread with a nut on it.
Quick Reply: Need Mezeire water pump info bad.
