lt1 383 build
lt1 383 build
im loading more pics and videos i just found out i can only get dyno time on sat to see how close my mail tune is cant get a tuner for a few more weeks so goona try on a mustang with 3.42 gears
did you get a mail order form a different source this time around? As long as they didn't tune it in speed density you should be just fine with the computer in closed loop naturally looking for 14.7 AFR, if your VE tables and your PE is all out of whack it might give you some grief when you get on it but you can't really baby a fresh rebuild either if you want the rings to seat so you are just going to have to use your better judgement and get it in to have a look at your AFR as soon as conveniently possible
yes difrent tune thats what ewre gonna find out on sat 70 for 3 pulls and were gonna check the af to make sure wer ok. its hard to fine a lt1 tuner in ohio, the weather is breaking and everyone is backed up.
