4L60E Plugs stuck?
Old 05-23-2010, 09:29 PM
jeepnut24's Avatar
Default 4L60E Plugs stuck?
I went to pull the plugs that go into the black selector switch and they wouldn't budge? Are they glued in? The plugs on my harness have some type of glue on them, and I can't get the plugs out of the donor transmission switch???? I really don't want to break it...
Old 05-24-2010, 12:02 AM
sawzall wielding director
G-Body's Avatar
I have heard of this more than a few times. From what I have read they are not glued. But the exhaust heat tends to slightly melt the plugs. I have heard that heating them up with a heatgun will ease removal. I have always pried mine out with a screwdriver, but I had not heard about the heatgun trick at that time.
Old 05-24-2010, 05:23 AM
poconojoe's Avatar
Heat it with a heat and what ever GM puts in there for sealer, might as well be glue, personally I think it is
Old 05-24-2010, 08:13 AM
Pocket's Avatar
I made it personal mission to get those plugs out of the last harness I did. Im pretty sure that stuff is glue
Old 05-24-2010, 08:48 AM
jeepnut24's Avatar
Good to know Im not the only one that is facing this...
Thanks for the tip, I will try a heat gun.
Quick Reply: 4L60E Plugs stuck?
