Will standard SBC rods work in a LS1 (6.1 length)????
The rod journals are the same correct? and i would assume the wrist pin is the same as standard small block chevy.
Is a stock rod 6.10 length or 6.125????
Because i could just order Eagle rods in a h-beam standard and pay like $250 for them if they are.
Senior Member
Re: Will standard SBC rods work in a LS1 (6.1 length)????
The stock LS1 rod is like a 6.098 and yes, the journal size is the same as the SBC. (2.100) You can use the 6.125s, but you have to get different pistons to change the deck height.
I dont know about the wrist pins though.
You can use the Eagle rods (either 6.100 or 6.125 long) but you need to match pistons to them, for rod length and pin diameter.
