Is the 4L80E the same size as the 4L60E?
Old 05-27-2010, 04:09 PM
omcar's Avatar
Default Is the 4L80E the same size as the 4L60E?
Is it a direct replacement in terms of size?
Old 05-27-2010, 04:19 PM
tx3
tx3's Avatar
bigger.. it'll fit with a lil hammer banging to the trans tunnel
Old 05-28-2010, 09:44 AM
poorhousenext's Avatar
It heavier, rear mount is about 3." inches farther back, Pan is longer but it is slightly narrower.
In my case the 4L80E has more tunnel clearance than a 4L65E. X-member was easy mod. Only fit issue was mounting tab on bellhousing. That seems to be a common problem. Had more clearance on sides of tunnel than with 4L65E.
Old 05-28-2010, 05:53 PM
omcar's Avatar
Thanks...good info.
Quick Reply: Is the 4L80E the same size as the 4L60E?
