01 LS1: Where to find the best engine assembly manual?
Where can I find the best engine assembly manual (torque specs, clearances, etc) for a complete engine? Its a 2001 Camaro LS1 that is the LS6 block (that shouldn't affect torque specs though). I'm getting the short block cleaned up, honed, crank polished, etc, and I'd like to reassemble it myself.
If the only way to get engine assembly specs is from a complete car manual, that is fine too........but which one is the best manual?
I tried searching for "assembly manual" on here, and all I got back were manual brake pedal assembly results!! LOL
Thanks
Thanks
Powertrain covers transmissions.
Shop/Service Information is what you want.
You want the vehicle service manual, item # GMP01F or GMP02F (they're the same, 02 probably has some corrections).
