Notices
93-97 Z28/TA ABS setup
Old 06-01-2010, 01:07 PM
Blacdout96's Avatar
Default 93-97 Z28/TA ABS setup
Need the setup for my 1996 Camaro, swapped it over from drum to disc and need the assembly for the correct proportioning block. thanks.
Old 06-02-2010, 05:29 PM
lw.jordan's Avatar
I have the ABS block i deleted from my TA and (i think) the pre-bent brake lines to the master. PM me if you need any of this stuff.
Old 06-02-2010, 10:35 PM
DMH Fabrication's Avatar
I have the abs block. PM me an offer.
Old 06-03-2010, 09:57 AM
Blacdout96's Avatar
Just to double check wiht you guys, they are from a 93-97 model Z28 or T/A? theres so many out there for the 98+ cars, but apparently they are different.
