JP performance timing set...do I need spacers?
i have a JP performance timing set part # jp5628T and I'm putting it in my ls1...i bought it from someone here on ls1tech...
i have the double roller cam piece/crank shaft piece and a bearing...I noticed some timing sets come with spacers...do i need one for my application???
thanks in advance
thanks in advance
More specifically as i've done more research I've figured out that timing chain i have is for a ls7 motor....will it fit on an Ls1?
If so does it need any spacers for the oil pump?
any help is appreciated.
