Can anyone tell me what these parts are
Old 06-08-2010, 12:10 AM
CubanGT's Avatar
Default Can anyone tell me what these parts are
While working on the car today, im working my way around each wheel well and checking cables out since the ABS INOP light is on.
So my first picture here i have 2 parts marked.. there seems to be a rubber peice that is no longer there what is that and can i find it somewhere reasonably cheap?
Pic#1
My second picture there are some connections made to the body right above the rear axle what are they?
Pic #2
My third picture there is a connection on the rear axle right in the center, what is that?
pic #3
Old 06-08-2010, 12:21 AM
NeedaV8foundation's Avatar
pic one is a bump stop this is what its suppose to look like
pic 2 i think is the connections for your abs/trac control, someone correct me if im wrong
and i know pic 3 i just cant think of the name right now...
Old 06-08-2010, 12:26 AM
CubanGT's Avatar
Are the bump stops something that can be picked up at auto parts store or is it a dealer item?
And if those connections are the abs / trac controls, is there a safe way to clean them and test them to make sure they are working properly?
thanks for the quick reply.
Old 06-08-2010, 12:51 AM
sjsingle1's Avatar
pic 2 is the bulkhead fitting for the fuel pump wiring and rear electrical..........no? GM no longer makes those bumpstops............there are many posts here about that........with poly replacements
Old 06-08-2010, 10:54 AM
idk ill go crawl under my car later and check to see what it is
