98 Trans Am, Predator
Ok i have heard thatyou cant use a predator on the 98 Fbodies if this is true is there any way that i can replace the PCM in my car or edit it in such a way that I could use a predator or would I be better off just buying a HPP3.. im not really sure what i should do. What are your guys suggestions on the matter?
SN95 Director
you heard correct, you cant use predator on 98's since they have a different pin setup.
just buck up and get edit, with atap/efi and edit you'll have far more tuning ability at your disposal then you have with predator. my whole tuning setup cost 1045, its not cheap .
get HPP3 only to raise rev/speed limiters and change shift points and adj. for tire sizing. other then thats its pretty worthless.
or just pay someone to tune your car with edit when the time comes. right now you dont have anything that warrents a tune anyway.
