Need pinion flange for u-joint on 06 GTO
Anybody know if GM has a pinion flange for u-joints to replace the flex joint on a 06 GTO rear end? Need to build a one piece driveshaft for a street rod using a GTO differential but I don't want to use the flex joint. I know that G-Force has one but it is pretty pricey. Also, will need a front slip yoke to fit the 6HMD 6 speed automatic.
Any help will be appreciated!!!!!!!!!!
1952 ****** Aero Eagle with complete GTO powertrain and front strut suspension.
