LS1 part list for Victor Jr? Those with a Victor Jr please chime in.
Am I missing anything?
- Victor Jr intake manifold
- fuel rails w/ adaptors for stock lines
- elbow depending on TB
- throttle body, whether a 4150 w/ hat or elbow with 92mm or 102mm.
- throttle cable? type?
Also, my car has been in storage for years and I am about to get it up and running again. Does anyone know if a Ultra Z hood provides anymore clearance for a Victor Jr with a Aaron's elbow? I can't remember the design of my ultra z hood underneath, but I thought it provided for clearance...been to long since I seen my camaro
Get the 4150 throttle body and a Spectre carb hat with the 4" opening. Fits under my flat VFN hood (the rear bracing had to be trimmed obviously). You will need 2 1/8" NPT to hose barb fittings. One goes in the side of the manifold for the MAP sensor (just use some 1/4" I think it is emissions hose to connect to your sensor). The other can go in the throttle body (depending on which 4150 you go with) for a catch can or whatever else you might need.
