84 security bypass ?
Is there a way to remove or bypass the security system on an 84 corvette. I have had everything replaced several times and I still have problems with "no start" and dead battery. Any help would really be appreciated.
i'm not at all familiar with the c4 vette, but owning a couple gm cars from that era, are you speaking of the VATS system? if so, grab a multimeter, check the ohms *resistance* of your chip key, get a resistor or resistor's +- %5 of your key and solder in the wires under your dash.
