K Member Bolts
Rockstar
K Member Bolts
In getting everything disconnected for dropping the engine I noticed there are several bolts holding the k member on to the front frame rails, as well as the sway bar seperately attatched.
I've helped with a few LS1 engine removals and installs and never noticed any under body bolts.
Will I have to remove these prior to dropping the engine?
any major work on my lt1 i just drop my motor 2.5 hrs and so much easier to get stuff done. the only thing that you gotta watch is the brake lines they like to hang up.
