T56 Chevelle Setup...Help Needed
Need some help with doing a T56 swap without buying the entire kit.
I'm going with a 2008 L92 and a T56 from a GTO going into a 70 Chevelle.
1) Does anyone have any experience with a CenterForce flywheel and Dual Friction cluth for this setup? The car will be around 550 HP.
2) What other parts will I need for the conversion with the hydraulic setup and where would you recommend getting the parts from?
3) What shifter do you recommend?
4) Has anyone ran a T56 in a 70 Chevelle and will this setup work with a factory console?
Thanks so much!
Thanks so much!
