Mods
Old 06-30-2010, 01:01 PM
LT1bird's Avatar
Default Mods
Ok, I have decided to go with a set of Hooker long tubes AIR and EGR Delete and run an X pipe bak to the magnaflows I have. An LS6 intake manifold. Solid motor mounts and poly trans mount. And a good dyno tune. What kind of hp gain should i expect on average. Car is a 98 trans am A4 it has a catback exhaust now and an SLP cold air intake. Just looking for an estimate i know all cars are different.
Old 06-30-2010, 02:33 PM
MonmouthCtyLS7's Avatar
330-340ish RWHP...Maybe more maybe less...w/ that limited amount of mods a mail order tune should be fine...you can find them here cheap unless you got someone local.
Old 06-30-2010, 03:16 PM
LT1bird's Avatar
So... i have a hand held tuner. is this what i need to use to tune it or would it be better to take it to a shop and have it done. There is a shop that does dyno tuning near by.
Old 06-30-2010, 03:18 PM
LT1bird's Avatar
Also, would it be worth the money to have this stuff installed at a shop or do you guys think these are fairly straight forward installs.( aside from finishing the exhaust out the back of the car)
Old 06-30-2010, 04:37 PM
jaysan's Avatar
You can do it yourself and get rid of the tuner
Old 06-30-2010, 06:54 PM
Lose the handheld tuner, it isnt worth ****...I think theres a guy on here that does kick *** tunes for under a 100 bucks...If you have the patience you can install things on these cars.
