'99 Trans Am, Front turn signals stay lit?
I just bought a '99 WS6 & noticed that the front signal lights stay lit when the car is running. They do blink just fine when I turn on a signal, but they just stay solid lit when the signal is not on. Is this normal?
Thanks!
Thanks!
It is normal, but you will have issues eventually. The DRLs run the turn signal bulbs on bright continuously and the heat causes the socket to scorch. I just installed new turn signal housings and replaced the sockets on both sides and went with LEDs. I'm hoping that fixed the problem. Keep an eye out for condensation inside the lamp housing. It's very common and will happen eventually. Be sure to use dielectric grease on the turn signal bulbs - that will help immensely.
